robyc »
https://forums.nicoclub.com/robyc-u5454.html
Sat Mar 29, 2003 10:30 am
After reading "Whats the difference between the S13 redtop and blacktop", has brought a few questions:
First, here is a quote out of HCI:
"Professor Baker does a great job with this lesson of informing us what JDM motor works best in what USDM Nissan 240. . . . If you stick to the same year chassis and motor configuration, this will help in the long run. . . . however there is no problem with putting an S-13 motor in an S-14 body and vice versa. The S-15 motor is the same as the S-14 motor except the transmission is longer, which would require an S-15 driveline. . . . the S-15 engine is the cream of the crop when it comes down to the JDM SR20DET motors."
I bring this up because I have a question, it eludes to the fact that a S14 motor is harder/more complicated to swap into an S13 chassis than a S13 motor. Does anyone know for sure?
Also, other than the S15 being newer, why would it be the cream of the crop, i.e. what are the performance advantages?
And this brings to mind, what is the biggest "bang" for the buck?
:jump
