S13 vibration ,shuttering ,from rear
mgp87zxt
Car: f%$&ing, cars, music
I have an 89 s13 that has been vibrating in the rear when i hit a bump under load or when i light the tires up in a right hand turn.similar to wheel hop
I have checked the suspension and drivetrain and everthing checks out pretty solid.
The only things I have noticed so far is that the transmission mount has a little play in it and the back suspension feels a little soft and worn.
Where should I look first?
Is there something else that could cuase this that I am overlooking?
__________________
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
SUB-FRAME BUSHINGS, transmission MOUNT, REAR TRACTION BAR BUSHINGS, TIRE BALANCE, ROTATE TIRES (IF POSSIBLE), THERE ARE A MILLION THINGS TO CHECK.
mgp87zxt
already tried the tires that was my first guess.
all the rear suspension bushings look good no cracks no play anywhere.
About how much play should the transmission mount have in it if any ?
This only happens when attempting to drift a right hand turn. when i light the tires up in a left hand turn all is good.
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
Umm...stupid question but are your tires properly inflated?
PROJECTRB240SX
YOU COULD POSSIBLY HAVE A BAD STRUT ON THE RIGHT SIDE OR THE TRACTION ROD BUSHING IS BAD. THE transmission MOUNT IS NOT A WORRY IF IT IS ONLY A SPECIFIC TURN YOU ARE DOING.
MysteryIncMan
Car: 1995 240sx SE
Mine did same thing. Struts were bad. Replaced them and made all the difference.
mgp87zxt
when you say bad strut you are refering to worn shock absorber , spring or both right?
PROJECTRB240SX
JUST THE ABSORBER, THE SPRING SHOULD BE FINE.
mgp87zxt
thankz for your timeI have noticed the shocks to be rather soft in the rear.
what are some good aftermarket brands?
prices?
I run tockico blues on my z's how do those work out for the s13?
PROJECTRB240SX
KYB, TOKICO, TEIN, BLISTIEN SOME OF THE BEST.
