Ok. The plenum- the spider inlet manifold has 4 long runners and 4 short runners. We grabbed a second set of short runners and discovered that if you used 8 short runners and make an ally adapter plates to suit the offset holes, you end up with 2 parallel banks of runners. This makes making a plenum to suit a lot easier. Inside the plenum there is flutes for each runner and a spine down the center for strength and to split air flow to each runner. The height also allows a stock bonnet to fit. It has a fast 92mm Ls1 throttle body mounted upside down.The injector spacing is also maintained to be able to mod you standard fuel rails to suit. It has 850cc sard injectors.
A custom throttle cable is hidden (throttle body mounted usd) under the plenum and fittings for ecu, booster vacuum and fuel pressure regulator at rear.
You may also notice that the cooling system is hidden, the y branch from the cylinder heads cab be reversed so it point backward. The water pump and thermostat housing and filler neck where removed and a new hose end housing was made to replace the original filler neck/ thermostat housing. This was done to be able to run a boot/trunk mounted radiator and hide the alloy tubes under the plenum that continue in 32mm OD ally tubes under the car to feed a au ford falcon cooling system. There is a Davies Craig electric water pump to splash the water around. There is also a -4 weld on, on the y branch that has a air lock bleeder and tees off to the filler tank in the boot to allow unwanted air in the cooling system to be relieved through the rad cap.
The exhaust manifolds where fabricated with Lazar cut flange plates mild steel tubes and coated with ceramic. The 2 bolt flanges are going to be changed to v bands to cope with the heat movement. The cross over pipe is in stainless 2.5 inch and has a neat mounting bracket that marries up with the timing chain cover where the original A/c idler pulley ( i think) would have bolted to. This Takes the weight if the turbo and also stops the exhaust manifold from walking to much. Where the 2 x 2.5 in cross over pipes merge there is a 44mm Teil gate which feed the screamer that runs out the right hand side of the front bumper.
The turbo is a Garret T04z with a 115 rear housing it has a 3.5 inch stainless dump which sneaks past a ca18 power steer pump on custom bracket, the oil filter relocation plumbing and the chassis rail then opens to 4 inch and flow through a magna flow muffler at the rear.
will post more detailed pic soon.
