So I've settled on the plan of putting an LS3 in my S13 240 vert. I plan to start this fall/winter. I think I can do it within 25k. Most everything over estimated with cost there should be plenty of options getting used or cheaper items. But equally if not more so it's more likely to go up than down.
I've read a ton of builds and web blogs about this build, this is really just a copy of those, tweaked a little bit because my car was auto. Good thing too, because I'd have idea where to start if someone hadn't already done it before.
Here's my parts list.
Engine/Trans----------------------------------------
LS3 Karls Performance........................8400
T56 TREMEC...................................3100
Engine Items/Swap Items-------------------------
CTS-V Accessory Drive System w A/C.......900
Bellhousing Adapter...........................660
MGW T56 QuickShifter........................230
Spec Stage 2 Clutch...........................400
Flywheel Spec Billet Alum...................410
Starter MSD DynaForce.......................300
Swap Kit Sikky.................................2710
Front Sway Bar................................300
Fuel Pump 300lph Deatschwerks............170
Fuel filter/regulator Fuelab FPR............60
Radiator Mishimoto...........................240
Rad fan Mishimoto............................180
Rad hose Mishimoto...........................140
Wiring (LS erod into s13 chassis)............500
Exhaust.........................................600 (might go up if I don't do it)
Manual Swap...................................300
Suspension -----------------------------------------
5 Lug conversion..............................430
q45 break/rotor set...........................600
Coilovers.......................................800
Bushing kit.....................................140
Q45 diff........................................300
Axle (driveshaftshop 500hp).................530
Misc(lines/cables/fluids/oils)...............500
suspension arm kit............................500
Rear Traction Arm............................200
Drift Stabilizer Bars...........................200
Tires/Rims.....................................2000
Total--------------------------------------------25800
How's the list look? Complete? Am I missing something? I want to make sure I'm estimating my costs right. Better to over estimate than under. I'm basically going to follow the build here:
http://speed.academy/parts-needed-cost- ... x-s13-s14/.
