Hijacker wrote:So long as there is a solid connection on that circuit, you're golden. Double check you don't have a blown fuse on the starting system. Also, ensure the starter is connected. Sometimes, the solenoid's ground can come lose and look like it's still connected. Also, are you using a manual starter or an auto starter? There is a difference.
thanks for replying. i actually got it to crank over. it was an oversight on my end. it ended up being a black and white 2 wires instead of the actual brown and black wires. but an issue i came across is everything is normal and operating well as far as lights go. BUT, when i turn on the headlights. the clock light turns off,but is on when i dont turn on the headlights. dummy lights still work. any suggestions?
