S13 VCT blacktop issue!
astro666
Car: PS13
hey so I'm having a weird issue with my S13
bought the car with a S2 S14 blacktop installed
ran and has been fine for over a year now, then a few months
back id be driving for about 30-40 mins depending on how hot
the day was, and it would just shut off. no coughing or spluttering
just shut off, like something was telling the ecu to cut power.
when it shuts its goes straight to reds everything still works and it still
turns over fine just won't start, seems like you cool it down for 10 15 and
it'll start back up and drive for 5 10 mins then die again?
I've changed CAS, IGN, CTS I'm about to try another ecu tomorrow
any ideas?
thanks aaron!
jackleberryfin
Car: Nissan Silvia S15 Spec R 2000 JDM
Might be useful to have a Nissan Data Scan log while its dying. If it doesn't sound like a mechanical stall. more of a electronic short. id be checking wires.
If your saying it depends on heat. Coolant temp might be an issue. or a busted hose from engine temp? honestly i have no idea ha! i hope the problem is found from one VCT backtop owner to another!
