S13 Vacuum Diagram
Hijacker
Car: '92 240sx Convertible
'94 F-150
Just finished translating this from the JDM 1991 180SX Service Manual.
I translated fairly literally on the names. So don't get confused by the AIV valve being called an EAI valve.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Subscribed.
duffman1278
Car: 89 240sx Hatch, the wildcats!
You sir are a GENIOUS! thanks goodness for this!
Hijacker
'94 F-150
Oops. I see an error already. The arrow pointing to the top of the charcoal canister says "3 way connector" on the diagram. I must have been not paying attention because it's supposed to say "Hose Clamp". Was looking over the original and saw I wrote in the wrong thing.
I'll fix that when I get home. I think I'm gonna go back and redo the numbers as well. Looking at them on my work PC is an eyesore 'cause they're so light.
HurryupandrunS13
Car: 1992 240 fastback
AWESOME diagram!!
notslow
Car: Nissan Sileighty
thank you God
Seedlessone
OMG I love you....
Rusker
Awesome work!
B-TownSX
Car: 91 240sx in middle of SR swap
How do you run the hoses if you are ditching the canister?
This is my guessUpper Left: BOV, FPR, Boost GuageUpper Right: Wastegate, Behind the MAFBottom: cappedCanister: Removed and capped with a breather
Hijacker
'94 F-150
If you're ditching the canister. Remove the hoses and cap off the ports you don't use. Not rocket science.
That's just a factory diagram everyone and their grandmother asks for. That's why I translated it first and made a jpg out of it.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
Nice. Now, what if you don't have the AIV or canister or boost pressure solenoid or AIV control solenoid or a SMIC? Just giving you a hard time.
Hijacker
'94 F-150
You can dunk your head in a 5 gallon bucket of cold carb dip
homeslicej2
Hijacker wrote:You can dunk your head in a 5 gallon bucket of cold carb dip
While this sounds funny...I don't quite get it
Hijacker
'94 F-150
The joke is only as funny as the punch line
Cold Carb Dip is the stuff you use to clean off parts overnight. It's like a step down from hot tanking.
I bet your face would be the cleanest it has ever been if you did it
homeslicej2
^hahaha. Never heard of the stuff though but you know all kinds of odd things about engine building.
Hijacker wrote:I bet your face would be the cleanest it has ever been if you did it
HurryupandrunS13
I see people bypass the boost solenoid a lot. The car still runs, but isn't that bad for it? Can anyone tell me the direct disadvantages, or effects of removing the boost solenoid?
Hijacker
'94 F-150
The selenoid's supposed to stop boost creep and spikes, not that that happens too often without it. Some members have reported their wastegates jumping to 10 psi when they removed it, but out of the dozen or so SR motors I've put in cars, I have yet to see that happen.
homeslicej2
^^I have no boost solenoid (usually don't get it with a motorset, only on clips). My stock T25 hits ~9 psi at peak boost, but I also run a 3" exhaust from the stock turbo elbow back. I've been told that running a larger exhaust causes the slight increase in max boost.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
ok i gota question. the small one coming out of the bottom of the throttle body can i use the to go to my FPR. or maybe my boost gauge.
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
i have a question too. can i tee off the bov signal to go to my wastegate?
duffman1278
david200095367 wrote:i have a question too. can i tee off the bov signal to go to my wastegate?
Yes
david200095367
duffman1278 wrote:
Yes
awesome thanks.
inkslingers13
Car: 1985 Corolla Gt-S
awesome man, very helpful! good work, i was just looking around the net to find something like this. thanks again ur brilliant!
Stratokat
Car: 1992 240sx Coupe
quick question, what diameter vacuum hosing is it? i'd like to order it online... but unsure to which diameter to get.
duffman1278
Why don't you just go measure it from your lines?
stentoria_s13
Car: 93 RPS13
yep if you ditch the can you can use the bottom port for boost gauge but it doesn't read vacuum. top right port is for fpr only. top left is to bov. wastegate actuator comes from hot pipe nipple. remove solenoid
Justin35ll
Car: s13 coupe sr20det
I use the bottom nipple as a wastegate source since it doesn't read vacuum because I don't have a nipple on the intercooler piping and this works just as goodTop ones I use for fpr, boost gauge, and bov
JRex
Car: 93 s13 Hatch
Hate to bring back an old thread but...I just wanted to check to make sure.
On the throttle body, the smaller (of the two) to left nipple is for the BOV, and the larger top right is for the FPR? or is that backwards?
