SHIFT_Lock »
https://forums.nicoclub.com/shift-lock-u8473.html
Mon Jun 16, 2003 12:15 pm
trannys from the s13 -14 are the same except yes the speed sensor. the long blocks aswell. if you ever decide to get a new motor from a s14 switch the manifolds(intake-exhaust) dist,coil pack,ecu,harness,egr/emissions stuff. and put it on the s14 long block and everything will be plug and play.
