popogto »
https://forums.nicoclub.com/popogto-u16338.html
Mon Oct 16, 2006 9:00 pm
i had a similar problem. for me it was very hard to press on the clutch sometimes thus not being able to get in gear. what caused it was a broken pressure spring from the clutch plate got stuck inside. if you can, take a look at the transmission. if its not the clutch/flywheel, then your pretty much lookin at a trany rebuild.
