s13 trans harness in s14
MooMoos14
I got an free s13 ka and transmission from my friend, so i put it in my s14. It used to be an automatic. but i swapped it to manual.. My friends also cut all the sensors and wires from my automatic transmission harnes... so i cant use that for my 5 speed.. anyways, I want to know how i can take the s13 transmission harness, and wire it up to work on my s14.
angrypenguin182
Car: 91' Nissan 240sx
was the s14 an OBDII if so chances are it's not im gonna have the same similar situation soon, im dropping a 95ka in my 91. the 95 ka's were made originally OBDI then halfway or something they changed to OBDII
MooMoos14
it's obd1
angrypenguin182
then it should be fine, im like 85% sure. Your lucky im gonna have to splice my harness look at both FSM's and like triple check each wire to make sure i wire the harness right haha
MooMoos14
I'm not sure that i can even use an s13 harness... just because of the fact that the s14 has like 6 or 7 plugs under the fusebox for different things like the altenator and start etc.. I dont think there is even a big difference between the s13 harness and the s14.
MooMoos14
angrypenguin182 wrote:then it should be fine, im like 85% sure. Your lucky im gonna have to splice my harness look at both FSM's and like triple check each wire to make sure i wire the harness right haha
are you talking about the engine harness or the transmission harness? if it's the engine harness, just use the s14 engine harness and ecu.. i think its 93% plug and play from there.
angrypenguin182
i was refering to both lol, and the reason im going to have to splice mine,is b/c my friend who's selling me the engine doesnt have the s14 harness just the ecu, he used his harness in the sr swap
MooMoos14
i have a full s14 body harness including the fusebox if you want that. the only thing i cut off it was the headlights.
