senioritis »
https://forums.nicoclub.com/senioritis-u18191.html
Sun Mar 20, 2005 6:42 pm
does it really matter? not sure if there's a difference but someone said "they look the same, same length and basic shape.. but the s14 uses a bigger output diameter, and, therefore, a different driveshaft. You also can't bolt up the s14 driveshaft to an s14 transmission on an s13 frame.. the s13 is too short."
is this true? got the parts for a manual swap but need a transmission so i just want to double check if this is true. thanks. and also how come most people say a manual ecu is not really needed for the swap and why is that?
