s13 transmission in s14
iheartu
I was wondering what I need to put a 93 s13 hicas transmission into a 98 s14? I know the basic parts but is there anything extra like any sensors or anything? Also how could you tell if the transmission has ODBII?
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
The connectors are different for the sensors and the speed sensor is different. An obdII transmission will have a CAS (or at least the hole and bolt hole) at the top front most edge of the flywheel.
FWIW I just slapped a s13 transmission into my obdII 96. I did not install the CAS into it, and the only sensor I currently have wired in is the speed sensor, and it runs great. This weekend I will be wiring in the reverse sensor properly, but I have no need for the other three sensors.
Now I do have an *** load of CEL's, or so I should, but I have had a CEL on this car for 6 years anyway.
If you are worried about that, then you can drill the s13 housing to accept the sensor and replace the sensor plugs to get it cel free...
