The car was an automatic converted to a 5spd. The voltage is right around .44v-.45v when back probed.onosqv wrote:Is the car an automatic?
I think mine read resistance backwards as well. The more important thing to check is the voltage - .4-.5 @ idle (most people like close to .45), and about 4v at max. Done by back probing those 2 wires I believe w/ everything connected - don't remember since it's been so long since I've done it that way, I have my tps reading from a gauge.
The thing is, I already tested, replaced or confirmed the proper operation of the following: coolant temp sensor, mass air flow sensor, oxygen sensor, spark plugs, spark plug wires, fuel pump, fuel injectors, fuel filter, air filter, distributor, pulled trouble codes (found none) and ignition coil. Now I can add the TPS to that. I also cleaned the idle valve last weekend due to the idle stumbling to ~300 RPM at stop lights.onosqv wrote:I'm 99% sure it's reversed for automatic.
If you didn't change out to the manual tps, that's most likely why you have the ohms backwards. Whatever your issue is, it's not the tps.
There's plenty of other things that can cause poor gas mileage (you'll have to search).
A few things off the top of my head:- bad coolant temp sensor (doesn't show up on the gauge, but if you have never replaced yours, it's worth the $20-30 investment for a new one regardless)- bad o2 sensor- bad iacv- dirty air filter and/or fuel filter- spark plugs, etc- base timing set incorrectly
EGR is deleted. Motor has 6000 miles on it.del82 wrote:Checked your EGR and PCV system yet? EGR for function/flow, and PCV for leaks, and if you haven't changed the PCV valve since you've owned it, you may as well, along with the grommet it sits in.
Given the gas mileage you mentioned, and the stumbling I'd have been looking at the EGR first, actually.
Oh, and then there's the question of actual mileage. If your motor's old, you're losing power and thus mileage, too. It's not as pronounced, but just something to keep in mind.
Again (this may help other ppl trying to diagnose your problem online), has the poor mileage problem been there since the rebuild/emissions removal? Or just in the past XXXX miles?Schrute Farms wrote:Motor was rebuilt by the previous owner who was a Nismo mechanic so I'm not thinking anything went wrong there (I could however be wrong... Compression is one of the things I want to test come spring). He also removed the EGR and all the other emissions stuff. I am going to hook the EGR back up and see if that doesn't help.
