meminto »
https://forums.nicoclub.com/meminto-u95701.html
Fri Jan 15, 2010 2:35 pm
Hi there, I created the video above...
The door trims, map light, interior light and S15 gauge cluster install I will do as seperate vids..
The door trims will be tricky, although from an initial inspection it should be relatively straight forward to fit, its the door handles that will pose an issue.. The door handles are not in the same position..
I am currently working on the painting side of things as part 2
Cheers..
