s13 to s14 transmission and driveshaft ?s
95hondakillr
Car: 240s
Searched but couldnt find anything valuable. Does anyone know if the s13 transmission will bolt up to an s14 ka ( i know it will bolt up and so will the ka24e transmission) without having a mess of wiring to redo or are the sensors from the s13 the same as the s14 wiring wise? Also just curious if the s13 driveshaft will work in the s14. Thanks in advance.:pface
hock08
Car: kouki
damn i have the same prob lol
Azrial
Car: 93 240sx vert, 1990 pignose hatchback roller
I'm not 100 percent sure but the only difference in transmissions is the crank angle sensors on an s14 it's not on an s13. I suppose if you want to know if the driveshafts are the same you could call the nissan dealer and get the part numbers for both. If they are the same part number they should be the same
S14's have an OBDII setup and the s13's don't atleast that's as far as I can tell from random magazines I have laying around
