S13 TO S14 TENSION RODS????? HELP
Vinchenzo
Car: 1990 Hatch
1993 Coupe
Whats up guys, I have a few questions regarding tension rods from the s13 to the s14. Heres the deal, im eventually do 5 lug conversion. So from my searching it looks like you need the S14 upright and ball joint hub and all that good stuff. Well my question is if it is are my s13 tension rods the same length as s14’s , and WILL MY S13’S BOLT UP THE THE SAME POSITION ON THE S14???The reason I ask is because my tension rod bushings are shot, so im looking to get SPL tensions, but I don’t want to spend $200 + for something that wouldn’t bolt up with the components from the s14. help is much apreciated
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
why not ask spl?
also, tension rods bolt to the lca. has nothing to do with the uprights.
Vinchenzo
Car: 1990 Hatch
1993 Coupe
ok i didnt know what it connected too thanks. Well do you know if it connects to the same spot on the s14 as it does on the s13?? But i will call SPL once i get out of school. appreciate it.
numbnuts240
2011 Ford Focus
2010 Mazda 3
are you going to be using s14 lca's?
adrianfromthecastle
Car: 1992 Nissan 240sx
s14 tc rods will fit, but they are considerably longer than s13 tc rods (like 1-2in.. which is a lot).
Basically, if you dont want to max your caster, I'd suggest just getting s13 tc rods instead.
I have v.3 spl s14 tc rods in my s13, but I had to remove one locking nut to accommodate in its length. But even with the removal of the locking nut, it was still about 1/2"-1/4" longer than oem s13 tc rod length.
Vinchenzo
Car: 1990 Hatch
1993 Coupe
numbnuts240 wrote:are you going to be using s14 lca's?
well do i need it for a 5 lug conversion, and if so then yes i guess i will be using it. so intern i would need s14 tension rods.. correct??
adrianfromthecastle
you don't need s14 lcas for a 5 lug conversion.
but if you do plan on using s14 lcas for whatever reason, then yes, s14 tc rods are recommended. s14 lcas are longer than s13 ones, and in turn will give you hella neg camber (will push out the wheel too)
Vinchenzo
Car: 1990 Hatch
1993 Coupe
this is exactly what i needed to know, thanks for the help
adrianfromthecastle
Vinchenzo wrote:this is exactly what i needed to know, thanks for the help
no problem my friend
