s13 to s14 distributor connection Please Help
hakosuka86
Car: Toyotas Nissans
okay my name is Akito and I have a s14. i just picked upthe distributor plug connection was broken and wires damaged so i went to the junk yard and cut a connection plug with sum wire attached to it so i could Integrate it to the damaged s14 distributor cables.
But the cables are different colors and im not sure which one is which i been looking around but i can find anything that tells which cable is which.
Has anyone ever done this and can anone please help me so i can finally combine this cables together and have the car running THANK YOU!!!!!!!!!!!!
bone_stock_240
Car: 1995 Infiniti Q45
The plugs for the s13 and s14 distributors are different.
hakosuka86
the connection fits actually
all I need to know is which cable is which.example:s13: black with stripe wire is positives14: which wire is positive
hmmm is there a way to tell which wire is for what
