s13 to s14 5 lug conversion
s13_maJiK
Car: s13
Ok i have a 91' without abs and i am looking to get 5 lugs from a s14, don't know if it has abs will check because i think it matters (correct? yes no). Also i read that you need to swap out lower ball joints from the s14 front to fit it on the s13, is the rear a direct bolt up? If anyone has done this swap just give me a heads up on what i all need. I searched and coulnt find to much on s14 5 lug swaps. Please dont flame and say search because i did. If u do decide to say search lets see wut you found before u tell me to search
s13_maJiK
Car: s13
s13_maJiK
Car: s13
BUMP^^^^^ garanteed someone has done this cmon now not everyone and there mom does the z32 swap
gumby74
Use the S14 front spindles. ABS hubs only matter if the S13 has ABS as well. You do not, so thats not a concern. You will want to run the S14 shock bolts as well. These are thicker than the S13 bolts. You will need to drill out the holes in your shocks to......5/8"? I think. Whatever the next size up from 1/2" is.Use the S14 ball joint (front) Moog p/n:K9820. Should run under $30 a piece.For the rears, you need only swap out the wheel hubs. There are 4 17mm(?) bolts around the axle hole. Remove and replace.enjoy.
