S13 TO R33 cluster wiring.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
I've done the s13 cluster wiring color codes to correct pins but can not find a damn thing on r33 instrument cluster wiring color codes to pins. I've found an s14 to r33 cluster wiring setup but i'd like to see an actual cluster wiring diagram if anyone has one. Here's my links and references.
Also if anyone has already done this and would be willing to just take pics of the instrument cluster plugs (wiring colors) i'll complete the write up on this matter. also willing to pay for those pics if your cluster works properly :)
http://i245.photobucket.com/albums/gg49 ... 0SXS-1.jpg
http://i245.photobucket.com/albums/gg49 ... UPDATE.jpg
http://i245.photobucket.com/albums/gg49 ... wiring.jpg
USMCgetsome
i also updated that other website zilvia.net which is where i originally began looking up the process.
USMCgetsome
http://i245.photobucket.com/albums/gg49 ... 0PLUGS.jpg
http://i245.photobucket.com/albums/gg49 ... LUSTER.jpg
found the r33 cluster wiring. Compiled a list and verified pin out and color codes.
USMCgetsome
RB PLUGS
LEFT TOP WHITE PLUG(A)
A1 ENGINE LT RD/WHT/SLVX2 AF10
A2 DOOR AJAR RD/SLVX2 MJ21
A3 AIRBAG BLK/BLU/SLV P521
A4 GROUND BLK/SLV DOT MHE2
A5 RIGHT TURN GRN/YLW/SLV LB16
A6 HIGH BEAM RD/GRN/SLV LA10
A7 SEAT BELT WHT/BLU/SLV P533
A8 OIL LT YLW/SLV DOT X2 NP01
A9 IGN & 12+ GRN/SLV DOT X2 MJ01
A10 EXHAUST LT ORN/WHT/SLV X2 NVO1
A11 CHARGE LT WHT/RD/SLV NM01
A12 LEFT TURN GRN/BLK/SLV LB15
LEFT BOTTOM BLACK PLUG(B)
B13 ILL- RD/BLU/SLVX2 MA19
B14 TACH GAUGE NONE C552
B15 VSS NONE C550
B16 2P/VSS BLK/SLVX2 MAE1
B17 SPEEDO GAUGE LT BLU/SLV DOT M001
B18 BOOST - WHT/GRN/SLV MA24
B19 ILL+ BLK/SLV DOT MAE3
B20 4WD GRY/RD/SLVX2 MF01
B21 SLIP YLW/BLU/SLV MA15
B22 VSS YLW/GRN/SLVX2 MJO4
B23 OIL GAUGE YLW/PUR/SLVX2 MA17
B24 BOOST+ RD/BLK/SLV MA18
RIGHT BLACK PLUG (C)
C25 ILL- RD/BLU/SLV MA25
C26 TEMP GAUGE BLU/BLK/SLV MA26
C27 NA
C28 HICAS GRN/WHT/SLVX2 CQ26
C29 FUEL GAUGE GRY/RD/SLVX2 NBO1
C30 ILL+ BLK/SLV DOT MAE2
C31 NA
C32 FUEL LT LT GRN/SLVX2 NNO2
C33 ABS NONE C516
C34 BRAKE LT YLW/BLK/SLV NB01
