s13 to 15 transmission
dl240sx
Car: rebuilding cars
i was wondering if you could put a s15 6 speed transmission into a red top sr engine?
ride4lame
the red button at the top will tell you...it knows ALL
BuudWeizErr
transmission, driveshaft and transmission crossmember needed. plus rear diff if you want a speed sensor.
May I ask why? You won't use it for drift or grip. You won't use it for drag racing (unless you are trapping at over 150MPH, which you'd have a better transmission for), you won't use it for freeway driving, unless you are consistently over 150MPH.
I'm looking forward to the day someone makes a 7 speed transmission, then it's going to be a war between the companies over who can make a car with the most gears.
:rolleyes
dl240sx
never thought of that before. you never need 6 gears when drifting.
ZERO
Car: AE86 GTS Liftback
I read an article on SCC or Super Street(I can't remember right now) they said that nissan had designed an 8 speed transmission for the R35 concept car. When taken to the track to be tested, the test pilot said that he rarely reached 6th gear, much less 7th or 8th. I believe it was dismissed as being unpractical.
sultan
BuudWeizErr wrote:I'm looking forward to the day someone makes a 7 speed transmission, then it's going to be a war between the companies over who can make a car with the most gears.
opel makes/made a seven speed transmission for one of their cars. a guy at school had a military buddy in germany ship him one to put in his vette, don't know why but he did put it in the vette.
ZERO
Opel is owned by GM. I'm guessing the perts are interchangeable.
KRPSICHI3
Car: I love to race, or anything else pertaining to cars particularly Japanese sports cars.
The S15 transmission is weak and expensive. It breaks very easily.
midnight brother
What facts do you have to back that up? Instead of just "hearing from a friend of a friends friend friend"
Fistantari
:rolleyes
Bugatti makes a seven speed.. check out their website, it's incredible. The buggati veryon is an AWESOME machine. For those of you that have never seen it before I highly reccomend you check it out. http://www.bugatti-cars.de/bugatti/index.html
BuudWeizErr
OK, now that we know there is a 7 speed available in the higher end cars. I meant a company for the middle class people. IE: Honda, Nissan, Toyota, etc.
And an 8 speed in the R35? Yuck.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
ive seen a 8 speed in a production vehicle, it may have been a big a$$ mack truck, but it had a 8 speed none-the-less. :D
tapdeznutz
since u brought it up about big rigs. i believe they have up to 12 gears or so. try and picture that.
