S13 TC Rod Install Question
high flya
Car: 1993 S13 240SX SE Hatchback (Project)
2002 E46 M3 Coupe (Depleting my $$$)
2015 YZF-R3
2011 BL Mazda3 GX Wagon (Beater 3)
I'm trying to reinstall my TC rods with ES poly bushings. Trouble is, the bolt hole on the bushing end of the rod doesn't quite line up with the one on the bracket (by ~ 1/4"), unlike the mushy stocks, I can't "finesse these. Raising or lowering the LCA didn't help. The only way I figured to do this is to push the LCA back until the holes line up.
Question is, will this cause damage? Anyone else had this problem?
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Yep. I had to use multiple pry bars and hammer...once I got it on the alignment rack all was good.
