Check this out for the question in your other thread: 240sx Speed Sensor tutorial. I am also unclear if the M/T speedometer pinion gear is interchangeable with the A/T pinion gear. I know the A/T speed sensor shaft is larger than the M/T shaft, so that leads me to believe that the pinion gears may not be interchangeable, but I have not been able to find any evidence of this and am unable to compare both parts side by side. I have the M/T speed sensor without the pinion gear as well. So, if someone has both types of pinion gears, it would be greatly appreciated if they were able to provide some input on this matter.placham wrote:
Here is my thread you can see how VSS looks like zerothread?id=378707
But since you have S14 you will not need it, since you have it on your auto trans. Sensor is 120 at parts store, and plastic gear is like 20 IIRC at dealer, dont know if auto/manual uses different plastic gear.
No, just no, wouldnt ever fit. U cant take a transmission out and put it in the same car, come one that wont work....1sikS13 wrote:will an s13 transmission fit in an s13, i have searched but have come to no conclusion, thank you very much
You can use the s13 speed sensor in an s14 chassis, but your speedo/odometer will not read correctly. I will be doing a write-up for drilling the hole for the CKPS when I get the template from another member This issue seems to be coming up more lately and hopefully it will be beneficial to other members who are unable to find an s14 bell housing also.s14derrick wrote:from my understanding all you had to do was swap the s13 manual speed sensor for the s14 manual speed sensor. but what do i know im still looking for a writeup on drilling the CAS hole on the s13 bellhousing
