rawphusion wrote:All parts minus coilovers is 2000.00 add another 1500 and you got 3500 in suspension parts. However is going to complement your S13.5 upgrade and your S14 SR20 engine install. If you going to spend 3000.00 to 4000.00 for an engine why not spend atleast the same to help you straighten out those roads.
raging panda wrote:I don't have first hand experience with all the parts you have listed, and neither do 80% of the people on these forums. You are going absolutely all out on a fully solid suspension, and nobody can answer correctly as to how it will come out because none of us have done it. From what I can gather, your ride will be absolutely harsh. I have heard that Japanese roads are smoother than american roads so it might not be so hard on you, but it will still be rought and you will feel every bump I'm sure. Basically you have suspension for a track car. You havent told us what your direction is with this, do you want a track car/daily driver/weekend racer, whatever. This sounds like a car you would drive to the track and race, but wouldn't drive daily. The suspension would be stiffer than a stock porsche I would think. Also the 400 or so horsepower would put you a little ways above some porsche models. You might want to add brakes and LSD to that list you have up there. Definately cheaper than a porche though. Like I said, few of us have first hand experience with all the pieces you have named, so everything I have said has come from whatever I read, so it might not all be true. Hope that helps.
raging panda wrote:What are you guys talking about? He asked a question and you didn't once answer it. Why should this thread be killed, I would like to know what the ride quality on the street is with all the solid/urethane bushings, I plan on doing something like this on my s13.
