Nismo_Freak wrote:Try adjusting your rear sway bar up a notch.
He said he has an OVERsteer problem. Stiffening the rear body roll will only worsen it. Although it is wierd that you have an OVERsteer problem and not an UNDERsteer problem.
The weight distribution is in the advantage of understeer.
I would guess that your oversteer problem is just a result of too much power, not how your suspension is setup. Maybe try laying off the throttle in the turns? A tire can only do 100% of one thing at a time. If all the traction your tire can deliver is being used for the turn, you can't give it any throttle, or you'll be over 100% and you'll lose traction. If 80% your tire's traction is being used for the turn, you can only give it 20% more with the throttle or you will oversteer.
I think you need some better tires, maybe even some wider rims, but you might be able to find some good rubber for the stock alloys.
