S13 suspension advice
jmontes228
Car: 1990 240sx fastback - 5 speed
100% stock ;)
Hey everyone,
Just bought a 100% stock 1990 240sx from an old man about a month ago and I'm starting to look into possible upgrades. I have big plans for the car and from all the feedback I've been getting I was advised to start with the suspension. It's my daily driver and I believe the shocks and struts have only been replaced once during the lifetime of the car so it definetley needs to be done lol any suggestions on quality parts for a good price? And what exactly should I look to replace. Realistically I'm not going to be drifting this car just looking for a smooth ride and great handling. Thanks!! :dblthumb:
Josh@NSP
Car: Nissan 180SX
Are you looking to keep the factory height or go lower? Coilovers are out of the question if you want a smooth ride although they provide the best handling. If you are wanting an upgrade, kyb shocks are relatively affordable and they offer adjustable dampening. After that, you could look into a slightly stiffer spring if you want, but factory springs can be re-used if you wish. KYB is only one of the many companies that offer good aftermarket shocks, they are generally the easiest to come across though.
One of those guys
Car: 1989 Nissan 240sx fastback- Drift missile
2006 Chevrolet Cobalt sedan- Grocery getter
I would suggest powered by max coilovers, seeing as you said you have big plans for the car, I would assume your either into drifting, auto-x, showing or something of that sort, good things I've heard about powered by max (I do not own these coilovers) is great price, wide dampening range, kick a** customer service, an awesome warranty. If your into the "herra frush" stuff then these have a wide range of ride height adjustability, if your into drifting they are wonderful, and I haven't looked into much about auto-x guys using these but I'm sure these would do just fine. If your not looking for coilovers then I would also suggest kyb. Anyways here's a link to pbm's site. And a couple other price friendly coilover options for ya
http://www.gtfactory.jp/cms/page.php?23
http://www.bcracing-na.com/products/br-type/
http://www.enjukuracing.com/products/%2 ... 52d94.html
Hope this helps man good luck!
