mechanicalmoron »
https://forums.nicoclub.com/mechanicalmoron-u183526.html
Fri Jun 14, 2013 4:01 am
I'd bet anything it's not your ECU.
But, it seems plausable that it could be your o2 sensor, which you can use your ecu to check, without a consult tool.
Could also be an intermittant heat-related failure, like a distributor/plug/wire problem, where a gap opens too wide for things to work right when it warms up.
It would be odd if it was this sudden, but it could be fouled injectors. Maybe you got bad gas or something. Or maybe you have a clogged filter, and you have the pressure at idle, but it can't keep up with higher flow and pressure drops with RPM. You could try injector cleaner or seafoam or something, and let it idle a while. Or a bad fuel pump or strainer could do that same thing, and keep up pressure until flow is higher.
It's not (entirely) your tps, but you could check your tps, it does cause funny shaking, i believe it controls advance - though it generally is only noticable at lower rpm - couldn't hurt to adjust it.
Check all your plug wires to see that they have the proper ohm reading (I think it's like 37 of whatever the smallest division a standard multimeter will have, or something like that)
One thing that I've never heard of causing problems, but that could actually restrict flow, if you really think it's that, is if whatever controls the butterflies in the intake manifold failed, and they're shut no matter what your main throttle is at - if I'm understanding them properly.
