Spartan325 »
https://forums.nicoclub.com/spartan325-u143108.html
Mon Jun 06, 2011 11:00 am
I have been having a similar issue in my '91, same engine setup. After trying several different ideas, I decided to pump the gas pedal while cranking. I pumped four or five times, followed by holding the pedal down all the way. After about 15 or 20 seconds of cranking with the gas pedal held down, the engine turned over. It did not want to idle on its own right away, but after a minute the idle normalized. We still have no clue what's causing the issue I'm having, but that's how I started her.
After repeated tests, I decided to try a driving run, about 10 miles down the road she began to massively overheat very rapidly. I pulled over and allowed her to cool and then drove home, we've tentatively identified the overheating as a blockage (possibly a rodent nest) in my exhaust pipes (or a bad Cat).
I know this doesn't help you find the problem and fix it, but... I thought I should share my issue. We THINK that the issue with mine might be a partly bad dizzy.
