twistedsymphony »
https://forums.nicoclub.com/twistedsymphony-u62853.html
Wed May 28, 2008 5:06 am
are you talking about building an enclosure for your door speakers?
For the amount of work involved with something like that the added benefit to the sound would be nearly unnoticeable.
considering the limited depth against the door you'd basically have to create walls in the door and seal it air tight, beyond the logistics of accurately calculating volume along all those curved surfaces you might end up having to separate welds in the door to get your pieces in place, nevermind the fact that it might not even be possible consider the other pieces inside the door that you're dealing with (window assembly, braces, electrical connectors, etc.)
The back might be a little easier (depending on the type of S13 you're driving since the coupe, vert, and hatch are all different) but even still it's a lot of research, time and effort for results that you probably wont even notice... automotive acoustics are pretty horrible as it is, add in road noise and spending time playing with speaker placement and enclosure design for anything but your sub is something you should only really worry about if you're building a competition system.
