S13 stcok fuel pump max hp?
mgp87zxt
Car: f%$&ing, cars, music
about how much power will the s13 stock pump provide before I have to upgrade?
dareo
Car: 1993 Q45, 1989 240sx
good question, consider how old yours probably is tho. Mines probably got the full 218k miles on it. I have no idea, so for me a replacement is just a good idea.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
I THINK IT CAN HANDLE ABOUT 275HP BEFORE IT STARTS TO STRESS OUT.
QUICK TIP ON FUEL PUMPS:FUEL PUMPS ARE DESIGN TO HANDLE 20 VOLTS MAX 8 VOLTS MIN.12 VOLTS IS EFFICENT BECAUSE MOST CARS ARE 12VOLT SYSTEMS. NOW IF YOU UP THE VOLTAGE TO SAY 18VOLTS YOU'LL GET WAY MORE PRODUCTIVITY OUT OF THE PUMP ALLOWING FOR MORE HORSEPOWER. USE AT YOUR OWN RISK AND I RECOMMENDA NEW FUEL PUMP WHEN DOING THIS.
Joe
IMO i wouldnt boost without a new fuel pump. its a very good, cheap, saftey precaution.
if you accidentally lean out because your pump cant keep up, boom. no more engine.
mgp87zxt
I use an air fuel ratio meter so thats not a problem but thanx for the info you guys.
Nismo_Freak
Car: 89 Nissan 240SX
It's 100 bucks... thats nothing in comparison to the cost of an RB series engine if the fuel pump fails.
Joe
mgp87zxt wrote:I use an air fuel ratio meter so thats not a problem but thanx for the info you guys.
lol i invite you to do some research on how accurate an AF gauge is.
its not ery accurate, more like a fancy light show than a gauge on how your engine is running.
you want an accurate reading you need a wideband o2 sensor.
wcbjr
Car: KA24E / hatch
a/f ratio meter could be a wideband...
fjo has a digital readout, it's classified as an air/fuel ratio meter.
Joe
a stock type o2 sensor is not sensitvite enough to give an accurate reading on a AF meter.
it has nothing to do with the gauge, the stock o2 sensor isnt made for showing a multi level readout.
wcbjr
Car: KA24E / hatch
He never said what sensor he is using is all I am trying to say. You are most likely right in guessing that he is using the stock one tho.
Joe
LOL if he wont shell out 100$ for a fuel pump what are the odds he is using a wideband o2 sensor
those damn things are ****ing expensive.
wcbjr
Car: KA24E / hatch
Haha, good point.
mgp87zxt
All I was saying is that if I went extremely lean the gauge would notice but Im not going to try and boost an rb without sufficent fuel in the first place,
But as for my ka24 thats another story... I want it to blow up for a better reason than running lean. and that will give me a good reason to start the swap.
thanx
Joe
heres the thing about thatrunning lean in GENERAL, yes you will see it on the gauge
but if something happens and you run extremley lean at just the wrong time, boom. you detonate.
SingleCamSam
I think it was PSI 240sx on FA that was running 750cc injectors with his stock S14 fuel pump on a KAT. But, as was said, if you have high mileage on your stock one it's a good investment.
