CC_nismo_240sx »
https://forums.nicoclub.com/cc-nismo-240sx-u93699.html
Tue Nov 25, 2008 5:54 pm
I'm pretty sure that the vacuum lines are hooked up in the properly. I used the vacuum diagram under the hood to route the lines. I did find one vacuum hose on the throttle body that had a crack almost all the way through, I replaced it and it didn't make any difference or fix the problem.
I didn't even think of the Throttle Position Sensor. Can you fix a problem like that without replace it or should I just go buy a new one?
