CC_nismo_240sx »
https://forums.nicoclub.com/cc-nismo-240sx-u93699.html
Thu Nov 20, 2008 2:44 am
I'm gonna try to explain this as best I can, I've done quite a bit of changes and replacing too my 93 Nissan ka24de 240sx.
My car is not starting! When I tried to start the car for the first time I primed the fuel system like you should and could hear the high pitch fuel pump winding sound, so I know thats working. I turn my key to the ON position and all my light on the dash work and I also hear the click that the ignition in the steering column makes right before you turn it over. I put the engine at TDC, front & back piston level to the top of the block right before the piston wants to fall which is the second notch on the crankshaft pulley. The distributor rotor is pointing right at the #1 spot on the cap, the spark plug cable leading to the front piston, number 1 cylinder. I measured the gap of the spark side of the spark plugs and set them to proper distance. Tested every spark plug cable and got good spark out of everyone of them. When I took the #1 cylinder spark plug out and looked into the cylinder, I could see the piston at the top in the TDC position. I also saw a light layer of fuel seating itself on the top of the piston, it was a thin layer but enough to notice. I replaced the starter and battery. I'm getting full 360 degree rotation in the engine, belts, fan and I can hear and feel the flywheel spinning but still no fire up. Looked over many of fuses and I couldn't find any bad ones, I looked over the whole cars wiring harness, every clip, plugs & connection, from what I can see everything is in nice and snug. All the proper amounts of fluids are in Differential, Transmission, Engine and Coolant.
- I've check all of this multiple times and the results are the same. - So the Engines TDC, I'm getting Spark, I'm getting fuel and the engine rotates 360 degrees with no weird sounds, knocks or anything out of the ordinary. - I did get two pops that sounded like combustion, first one then the second, its sounded like it wanted to start after the combustions but the it stopped and the engine kept rotating with no start.- I am still using the AT ECU but have a 5-speed transmission. I hear it everywhere that is doesn't matter if you use the AT or MT ECU after doing a transmission swap, you actually get some advantages from using the AT.
ALSO WORTH MENTIONING: Installing the Timing Chain, Guides & Tensioners. The timing chain has alignment and mating marks on it, I made sure that they all were in there correct spots while putting together the head. The engine and pulley are still at TDC. The camshafts are in, I get to the camshaft sprockets and bolts them down making sure the small dot on the sprockets are alined with the upper timing chain mating marks.
NOW, with that said and the engine can rotates freely 360 degrees and I can't hear any abnormal noises, I'm assuming that the camshafts are on properly and the valves & pistons are not coming in contact with each other? If I'm wrong, let me know....
* Is it electrical or some type of sensor?
* Would it possible be a fuse or relay?
* Does the ECU and or does the transmission swap have anything to do with it?
* Is there anything I could check, test or replace that might fix this unexplained problem?
---- ---- ---- Feed this post with any feedback or suggestions possible, this is really frustrating ---- ---- ----
________________________________________________________________________________A list of some of the changes and installs I've done that might help diagnose my problem.
1. New Starter2. New Battery3. New Thermostat 4. Cylinder Head re-surfaced & New Valve Seals 5. New 1 Piece Aluminum Driveshaft6. AT to MT Swap 7. New Clutch Kit & Flywheel8. Viscous LSD 9. Timing Chains, Guides & Tensioners10. All New Belts11. All Major Gaskets - Head - Intake Manifold - Exhaust Manifold - Throttle Body - Water Pump - Valve Cover - EGR Valve - Thermostat Elbow
12. All Major Seals: - Front Main Seal - Rear Main Seal - Transmission Rear Seal
13. Properly Lubricated all moving parts in the head with Redline Lubrication.14. Cleaned carbon from pistons and ever surface that required a gasket or RTV free from oils. 15. The Spark Plugs are fairly new as well as the Cap & Rotor, not even 6 months old. The Spark Plug Cables were on the car when I bought it about 1 year 1/2 ago. But again I am getting spark.
16. A whole bunch of new bolts, all water pump bolts, valve cover bolts, timing chain front covers bolts, camshaft caps bolts, all new Transmission Bell Housing bolts, Starter bolts, Flywheel & Pressure Plate bolts and many more.
Modified by CC_nismo_240sx at 1:37 PM 11/20/2008
Modified by CC_nismo_240sx at 2:16 PM 11/20/2008
Modified by CC_nismo_240sx at 4:44 PM 11/20/2008
Modified by CC_nismo_240sx at 11:59 PM 11/20/2008
Modified by CC_nismo_240sx at 12:02 AM 11/21/2008
