Number 1 is the constant, number 2 is the ignition(so only gets power when you turn the key),3 is the ground. So I have good connection with number 1. Its number 2 is the one thats weird. So the clip thats connected to number 2 only gets 12v when you turn the ignition on, correct? So heres my problem, if I take off the clip off of the solenoid and I test voltage from the clip itself I get a constant 12v but if I test the voltage with the clip CONNECTED to the solenoid I get less then 1V. Weird thing is that if I jump numbers 1 to 2 with the starter grounded everything works fine! WTH CAN IT BE!!!
