hmm... probablysr20power wrote:I'm not sure and correct me if I'm wrong but aren't the bolts on the knuckle different in size from S13 to S14?
thinking if he got the right coilover for the S13...
Yes, the bracket where it connects to the steering knuckle. Those bolts, sorry.sr20power wrote:assuming he's talking about the bolts for the knuckle
Yes, this is what I thought as well, however, they are too big (around) for the holes in my coilovers.adrians_s13 wrote:what bolts? where they connect to the knuckle? Those should be oem.... you're probably not lining the holes correctly.
This is what I figured was the issue, but I wasn't sure if I'd have any problems drilling out the hole on the coilover. We've already planned to do that tomorrow, so I shouldn't have any problems later on because I drilled the holes, right?NISMO24096 wrote:maybe I'm wrong but did they convert your car to 5 lug by using the front knuckles from a s14, if so just drill out the coilovers and be done with it.
??? OEM Size bolts for what?Ter240sx wrote:i have a s13 and did the same exact thing you did, going from KYB to GR+PRO's. just use OEM size bolts and it should fit. i had some mismatching ones in my KYB's as well for some reason and luckily had my buddy's parts car sitting 20 feet away and we just took off the OEM bolts and used them for the Stances.
Whiteline in the front & rear.DJ_SLapo wrote:What brand sway bars did you get?
Thanks. I picked up the convertible shell and the suspension was pretty much blown from day 1. When we put the RB motor in it got much worse and now I can't stand driving the car because the handling just feels terrible, but I think these parts will change that entirely. Did quite a bit of research, saving, and part gathering to get this far.nevertheless wrote:Yummy. Your gonna love your new set-up. I have the same coils except i got the ALs, and the same brakes.
Read the instructions that came with them.DALAZ_68 wrote:any chance you can point me to how to set coilovers...i know how to install em...but i dont know how to set ride height and s***...there brand new Stance GR+pro's so there not preset to anything...
