If you are looking for a brand new wiring harness that will completely replace every wire connector and ground then this is the harness for you. No splicing or modifications required - OEM fit and finish with a STARTUP GUARANTEE.
Engine harness: $319 - - Transmission Harness: $99 - - Combo Harness: $409
Order here: http://www.wiringspecialties.com/s13sr20det.html
Wiring Specialties Harness Features:
- Plug and play
- No cores or additional wiring required
- Point to point continuity checked
- Constructed using brand new OEM connectors and seals
- Improved grounding
- Retains OEM wiper functionality
- Retains Cruise Control and all gauge functions including speedo and tach
- Works with the Greddy/Freddy intake manifolds
- All A/C, Temp override, Auto On/Off functions properly
- OEM wiring connections and 'T' junctions. No soldered connections at all
