S13 sr20det vs. S14 sr20det
toofancy83
whats the main difference between the s13 SR and the s14 SR? i know the s13 came in the older red top and the black top, but the s14 is only black top and has that slant at the back and produces a little more horsepower. are the internals the same though?
thanks
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
You fail at searching. Please do it. zerothread?id=59346
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
redtop91 wrote:You fail at searching. Please do it. zerothread?id=59346
IBTMFL!!
karmakaze
Car: 98 240sx SE
however, that is an old thread with old information in it. almost all cam manufactures offer a full range of cams that work with VTC (NVCS) now.
redtop91
Really?!?!? Damnit that was my whole reason for passing on the S14/S15 SR's. Guh. Buying an SR in 2001 FTL.
homeslicej2
You bought your SR 6 years ago and have only put a few thousand miles on the car?
redtop91
I just got my license last year and installed the SR during the summer (06). I'm WAAAAAAAYYYYY before the bandwagon. The pieces are just now coming together.
homeslicej2
Wow. The motor sat around for 5 years. That's incredible.
redtop91
I sealed that thing up like a space shuttle. Every last whole was sealed and epoxy coated. Getting the stuff off was a b1tch though.
homeslicej2
That explains how you did your swap so cheap. I bet you got the motor for about half what they go for now.
redtop91
Motor was free.
karmakaze
Car: 98 240sx SE
redtop91 wrote:Motor was free.
well then you really don't get to complain about not having VTC.
redtop91
Indeed. Karma is your whole block cyro treated?
karmakaze
Car: 98 240sx SE
redtop91 wrote:Indeed. Karma is your whole block cyro treated?
yes. except for bearings which i need to buy and the forged parts that i bought/am buying to bore it out to 2.2L (rods are the only other part i still need to buy, and main studs i am considering replacing because of my high redline)
bearings will by cryo treated once i get them, and i may even get my pistons and sleeves done, depends on price and time.
redtop91
You cannot cryo the rods?
homeslicej2
free!!!! AHHHH!! Mine's da*n sure not free. That must have been nice man.
karmakaze
Car: 98 240sx SE
redtop91 wrote:You cannot cryo the rods?
you can, and i might depending on money. it would probably cost around $80 to do all 4 of them including shipping. at the power i plan to be running at i am overkill enough already, i might as well save the money. only reason i want to cryo the rods and sleeves is to reduce friction and the reinforce the sleeves because of how thin the walls are after you bore it out to 90mm.
