s13 sr20det redtop crank pulley removal, for seal replacement?
double_jd13
Car: 96 240 w/s13redtop
cant figure out best way to remove this pulley. i know it doesnt have the normal three holes for using a normal puller. and it obviously seems to be a harmonic balancer also with the outside pulley riding on a rubber cushion. any help would be great.thanks jason
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Id remove it like we remove the pulleys from our Q45.
I bought a 2 jaw puller from sears for $30.. It attaches to the lip of the crank pulley... dont pull from the rear lip, do it from one of the middle lips, the ones there are stronger than the one in the rear...
Remove the bolt from the crankshaft, and take off the thick washer/spacer and then put the bolt back in a few turns, just enough to secure it in there... Then put the puller on the crank, and voila!!
double_jd13
thank you.. ill head to sears and see if i can find that puller.
jason
