Weasel of Doom »
https://forums.nicoclub.com/weasel-of-doom-u78214.html
Wed Oct 10, 2007 6:16 pm
Just a few questions so maybe I, or others, can help:
What type of AFC do you have? What do you have it set to for 'In/Out' on the HotWire setting? <assuming APEXi SAFC of some sort>
Has the car run fine before, or is this a problem that has never gone away?
To me, it sounds sort of like you have a setting for Dec. Air (based on you saying the car doesn't stall), and maybe perhaps you haven't setup your TPS sensor in the AFC, so it knows when it's closed and when it's WOT. If the car struggles from idle with minimal gas, but does reasonably well semi-floored from idle, that would almost certainly be the problem.
Sorry, that was all extremely hypothetical, not knowing any extra information.
Hopefully this helps, and if not, shoot up some more information and I'll take another shot!
~Weaz
