I would love to make some extra money, but trust me, it's not hard to make. I don't have access to an S14 either, so unfortunately I would not be able to cut it correctly and would send you something that might not work. Thanks for the offer though. All you need is a large piece of cardboard (to make your template), a 24" x 36" piece of sheet alum from Home Depot/Lowes/etc (this size is large enough that I can make two panels for the S13), a 4 foot long piece of 1 1/2" angle alum (this was the shortest length of 1 1/2" I could find), some bolts to mount the sheet to the rad support, a drill and bit, some tin snips, and a hacksaw (or whatever to cut the angle alum). Took me about 45 minutes to make mine. Get under the car, cut your cardboard to approx. size, press on it to find the T/C rod brackets and the pre-existing bolt holes, and cut it out, then transfer to the alum. Your bolt holes might be a bit off, but that's why you get a piece of alum big enough to make two When I cut mine, I slid the cardboard and alum under the FMIC till it touched the bumper cover, then cut out the bolt holes and bracket spaces. So the sheet goes from the bumper cover to the rad support.
Sil80315 wrote:Very nice mod
motorboater wrote:like that setup looks nice
Thanks
