I totally disagree there....You're telling him to put the BOV on the cold air side of the intercooler before the throttle body? Yes it might give a slight slight slight difference in throttle response, but your also blowing off cold air...most of use find it more efficient to have the bov before the intercooler.....AND the fact that putting the BOV closer to the turbo the better....You want to have as little air forced back into the turbo as possible, and placing the bov closer to the turbo allows for that.....Thats pretty much your whole point of having a BOV...I know there are some benefits of what your suggesting, but thats not the most common placement, and definitly not the best for the longevity of the turbo.Daunttless wrote:The hotpipe is usable, however the closer to the throttle body the better generally, it provides a mucher quicker response for the BOVs duties. However the hot pipe is another perfectly acceptable place. : )
Yes, but i still can't understand you at all...Yes, mine is in the fenderlining, on the side of the turbo....you keep mentioning Throttle Body, and Fenderlining, which would refer to the other side of the car. My BOV is not on the side of the TB, but on the side of the turbo....conprende'? Hotpipe, drivers side...Throttle body, passenger side. I have by BOV located on the drivers side..(IN AMERICAN 240>....LHD)....so its closer to the Turbo than it is to the throttle body, and its on the inlet side of the intercooler....daunttless is confusing.Daunttless wrote:Jesse and I had differing viewpoints as to our definition of hotpipe, I had the same problem on the old board with downpipe/midpipe/testpipe/dumppipe, etc. : ) By hotpipe I meant conected directly to the turbo, and Jesse meant the entire pipe between the turbo and intercooler. I would put it in the fenderlining, as its closer to the throttle bottle but farther away from the turbo, better response and less chance of accidental compressor surge. Jesse has his in the fenderlining. : ) Sorry for the confusion, right next to the turbo would work just fine, but I like the fenderlining, and if you are into it, a lot of people think its louder out there.
And, everything that hurddawg said. : )
well, my intelligence leads me to believe by that post, that you are refering to the fenderlining in the passenger side of a US 240...correct?Daunttless wrote:I would put it in the fenderlining, as its closer to the throttle bottle but farther away from the turbo,
Chris69427 wrote:I gotta side with Nils on the BOV issue. Think about it, guys, when the throttle body is open, all this air is just going into the engine, right? So what difference is it to the turbo, if instead of going into the engine, the air is vented out through the BOV right by the TB? None! So why confuse your MAF sensor by locating the BOV close to the turbo shaft? It only feels like it's releaving the pressure closer to the source, but the turbo doesn't know the where the BOV is; it's just pumping air and if that air goes somewhere even if into the atmosphere after the intercooler, it's not hurting the turbo any more than when the throttle blades are open at full boost under normal operation. Long winded, I am, yes, but doesn't that make sense (if you can decipher what I'm trying to say)?Later, Chris
I H8 UR DSM wrote:id consider the fact that the most important reason for having a bov, is to release pressure from going back into the turbo in the wrong direction....putting as close to the turbo as possible would extend the life of your turbo the most...
