S13 sr20det loud ticking noise.
kapetaJR
Car: 1993 240sx. ( Work in progress)
Hi guys,
Just need some help, my buddy has a s13 sr20 blacktop motor he just swapped into his coupe. Motor was running in another car before with no problems, my buddy got the motor, get into the car running fine for a couple of hours, he took it around the block a couple of times with no problems, but as he was pulling into the driveway the ticking started happening, we think its coming from the head.
What we have done so far:
- Swapped in 2 lifters we thought where making the sound - didnt help
- Pulled out the lifters and bled them all - still nothing
- Pulled the oil pan - oil was clean with no shavings or any thing that didn't look like it belonged.
any ideas what it could be? We were thinking of pulling the motor and inspecting the bottom end as a last resort, but wanted to get other opinions first.
[youtube]http://www.youtube.com/watch?v=68U-8-ryyLk[/youtube]
thanks for the help.
Blown240sx
Car: 1996 240sx
Well first off stop running the car. Have you checked the head for oil? Seems you may have an oil pressure issue. Any oil pressure gauge hooked up?
kapetaJR
Head is getting plenty of oil, we took of the valve cover and took out the spark plugs and tried to crank it, oil was flowing to the head with no obstructions at all. No oil pressure gauge installed.
Blown240sx
Car: 1996 240sx
Well the loudness of that ticking indicates to me you dont have the right pressure. You should have 40+ psi on cold start.
Have you pulled one of the cam caps off and inspected the journal and cam to see if its scarring?
kapetaJR
Yup we did that too, no scaring on either cams that we could notice. I wlll see if he has an oil pressure gauge he can install and see if we can verify that.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Also, get a catch can and recirc that hose on the exhaust side. Bad things happen to SRs when you leave breather filters on there...
kapetaJR
PyR0NiAk wrote:Also, get a catch can and recirc that hose on the exhaust side. Bad things happen to SRs when you leave breather filters on there...
Ok.. he is still running the stock catch can, should that be good enough?
ciscos13
Car: 89' 240sx hatch, s13 sr
well on my sohc ka24e (when i had it) it made that exact noise but it was the timing guide chain that was worn out. i would be driving it for a couple of mins, about 30 min or so then it went away. about two three days later it came back. but idk if srs have the same problem. hope this helps.
PyR0NiAk
Yeah, but he needs to recirculate it to the intake.. I definitely recommend doing it post MAF if you're only running the stock catch can. Pre MAF should only be if you put a 2nd catch can between the T fitting and the intake. (You don't want your maf sensor getting oil on it.)
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Agreed, definitely run the hose back to the intake. I decided to ditch the entire catch can deal and just run the stock hose from the front of the valve cover T down to the intake tube. That is... If i can find a brand new one.
PyR0NiAk
OM3GA wrote:Agreed, definitely run the hose back to the intake. I decided to ditch the entire catch can deal and just run the stock hose from the front of the valve cover T down to the intake tube. That is... If i can find a brand new one.
No way I'd do it without a catch can, bro.
OM3GA
you dont think so? I just cant find room for one lol. I bought an oval greddy and sold it and bought a mini CS one and its been 4 months and i still have not received that thing. Its on back order :(
