S13 Sr20det into the 1996 S14 240sx Wiring? Help Please!
drift240sxtm
I have been looking at wiring diagrams for ever now and i have checked the forums and all i can ever find is the s13 chassis with a s13 sr or s14 sr in it for wiring harness. I have the service manual (lucky me though all the wiring diagrams are pulled out) an really nothing seems to match up as in colors. The dash connector going up to the water temp, speedo, tach, ign, and ground doesnt match up color wise on any of the connectors so im not sure which connector I should use and the iacv, fuel pump, ecu power, ecu relay, back up power, ac relay, etc. do not match up were u cut off the connector on the sr and put the ka plugs on. Any ideas or anything for tat matter. Thanks
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
The best thing 2 do is leave it to the pros! but you relly have to be carfull if you have never done it b4. The price for a turn key harness is around $400. Thats what I payed but I would have done it myself had I known how. From what I heard Its not hard. FRSPORT has a wiring page that might help. s13 sr in s14 is a little harder. If I had all 4 harnesses I would take my harness out 4 a template and rewire a new harness to 100% and sell my old 1 only beacuse its not 100%. GOOD LUCK!!!
joshuasdad
Car: 1996 Nissan 240sx
did you find anything? pm me please
