Rican_Nick »
https://forums.nicoclub.com/rican-nick-u5164.html
Mon Apr 24, 2006 5:38 pm
i have been trying to help a buddy resolve a strange issue on his SR swap that was completed last weekend.
Car info..97 Kouki with s13 blacktop sr20det Stock e6 ecu. The swap itself is very stock.. SMIC, Stock BOV, stock downpipe. Only known mod on the motor is a M's K&N intake. HKS Wastegate actuator.. from waht we can tell it is set to stock boost.. but not sure if we are building full boost due to the rev limitation.
quick rundown on where we are at.
Problem- Will NOT rev past 4k, at WOT the motor sits on 4k as if there was a ECU controlled Ignition/fuel limiter. Also having cold start issues.. takes 4-5 times to crank over. the motor will idle fine.. but the slightest load or revving causes it to "break up" occassionally.. some times it will rev up to 4k even building boost appropriately and then hit 4k and not rev past it at all.
things we have done checked.
Motor Grounds- Goodnew plugs- Gapped at .34 ish.. Will gap these down to about .30 which is what i ran on on my plugs stock boost.Tried my Working maf - nothingVerified the Timing and it is on pointNo boost leaks that we have foundall connectors have been checked/cleanedWe have checked voltage at TPS/Maf/coil packs.. all check out finewe have checked the 5th gear sensor to verify it hasnt gone haywire--this usually causes problems at 5k rpms though.. but we are running out of Ideas.
does anyone know of an ECU imposed limiter that would limit the motor to 4000rpm.
I have found many other threads with the same exact symptoms but none that state they were able to fix the issue and/or how they resolved the issue.
Any help would be greatly appreciated..
