s13 sr20det into s14 auto???
l8apex
Car: buncha vws 98 240,
ok, so we droped an s13 sr20det in to a s14 automatic folowing a write up we found on zilvia. Its still not working. Do you know of any other writeups?
I searched
thanks for your help
l8apex
im struggleing here folks
BLKTOPS14SR
Car: 1998 Nissan 240SX SE Kouki
1971 Buick Skylark 455Buick big block
1970 Cutlass Holiday Coupe
2002 Ford F-150 XLT
1972 Chevy Cheyenne
Man your sig is hilarious! But yeah search on here. There is a write up on it. I've got a 95 Zenki and going to be installing a S13 Redtop. I haven't been hearing good things about Zilvia here lately. The guys on here should be able to help. All I know is that the power plugs are under the dash instead by the battery on S14's and if you have abs your right front sensor won't work unless you wire it to power. Same goes for the wipers. Makes sure you have all connects soldered and heat shrink and not twisted or crimped. Hope that helps alittle.
