S13 SR20DET into a 95 240sx
raven3800
Hey guys I'm new to the site and just have some questions about a swap I am doing. I have a customers car here at my shop for an SR20det swap into his 95 240sx. I have been seraching on this site for two days now looking for any info on swapping this engine into the S14 chassis and I am finding nothing. I can find a ton of info about swapping into an S13 chassis but nothing about the S14. The only thing I seem to get is ...try searching..well I have tried that and I get nothing. I even tried to search the SR20DET (rear wheel) section and it comes back with no search results. When I go through the steps for the S13 chassis everything matchs up with the SR harness but nothing on the car side of things is the same. The Dash connector is different and for the life of me I can't find these two plugs that are suppose to be on the end of the KA harness (can't find the black with pink. Does anyone have any links that I can read up on about this swap into a 95? Again I have searched and it's coming up with nothing...hoping someone can point me in the right direction.
Thanks
Hijacker
Car: '92 240sx Convertible
'94 F-150
You need to cross reference service manuals to get the proper wiring. Since there's no JDM wiring section out on the net currently, you can use the USDM KA manual. It should have everything you need save the ignition system. But that's easy. On the S13s, there's a blue/red wire going through one of the two plugs at the end of the harness that supplies power to the ignition. Tap it into an ignition switched power source. The black/red wire works best.
The reason you can't find the mate for those two plugs is that Nissan did away with them on the S14 chassis and all the wires were rerouted through the gigantic dash connector.
What you need to do is take the electrical sections of each manual (EF/EC and EL) and start cross referencing all the circuits to make sure you reroute all the wires properly on the S13 EFI harness. You will also need to move the S14 wiper circuits off the S14 EFI harness onto the S13 EFI harness.
The reason you found little info on the subject is that most people here get frustrated doing all the work required and send their harnesses to professionals such as Taylor Durdan or Wiring Specialties.
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
i would start with googleing the pin outs for both ecu's they should each have reference codes on the lower portion of the case. I would also suggest studying the fr sport s13 wiring diagram and your fsm, you might also want to contact heavy throttle jeff is usually willing to help. There are also companies on this site that can wire your harness for a few pennies (usually doesn't take to long and worth the $) you beat me to it
Hijacker
'94 F-150
James,I don't know how familiar you are with Nissans, but Nissan does a good job of making sure that certain wire colors do certain jobs, even across the generations (hence why the S14 wiring diagrams are still useful the S13 guys)
raven3800
Awesome, thanks for the reply guys. When I dropped the dash connector off the PCM that is exactly what I was thinking would have to be done. I have done major swaps before where the PCM has to be repinned (my personal car.. http://www.cardomain.com/id/raven_sc3800 ) but I wanted to make sure this was the proper approach before I starting digging that far into it. I should be ok from here thanks again.
raven3800
First one I have worked on this in depth before but I'm a quick learner. :P And I did notice that as well, if you compare the us version S13 and S14 it does seem that they share the same color coding.
Hijacker
'94 F-150
James, once you're done, you shoudl post up pics of the process and some advice to help others that want to swap S13 motors into their S14s.
DRIFTING.com
we are going to cover this in a DVD soon, just waiting for the S14 harness (1-2 weeks)
raven3800
lol...if you want to do it for me (at a reduced cost of course for being the guinea pig ) I can have you a harness by Monday morning.
One other thing I was wondering about is the ABS. Since it is controlled by the stock ECU it is not going to work with the SR ECU. I was thinking of just eliminating it and running a proportional valve from one that did not have ABS. I suppose you could piggy back the stock ECU to retain it but IMO would not be worth it.
Hijacker
'94 F-150
ABS isn't controlled by the ECU on these Nissans. S13s and S14s have a seperate control unit for the ABS system.
Taylor_Durdan
well, thank god he's going to correct route and having me do the harness. only problem is that it was supposed to be on my door step 3 days ago, but atill hasnt arrived.
held up in customs?
smp-16
Car: 95 240SX LE
Hey Taylor , Its Shane , I originally asked you about the harness.Anyway me and James are trying to get ahold of you to see whats up .You can call me 1 (902) 441-9397 or James 1-(902) 850-3330
smp-16
Car: 95 240SX LE
Weird , his phone doesnt accept incoming calls .
Anyone one know Taylors email or how I can get ahold of him? Purolator said the parcell was delivered just want to know whats going on and when I will receive it back .
Taylor_Durdan
yo! phones good now. tmobile pisses me the heck off.
the harness ended up coming in on monday. ive got it all done now. will be shipping out htis weekend/monday! hope you like it!
Slipstream
Car: '94 Sonoma, '90 300zx n/a
Tayler: How much do you charge for the harness wiring?
smp-16
Car: 95 240SX LE
ship it! haha im excited now man !
Thanks for the response I was almost ****ting my pants
Taylor_Durdan
im shipping it this morning (yest was columbus day- boo) although i havent received my payment from him yet.
Taylor_Durdan
Slipstream wrote: Tayler: How much do you charge for the harness wiring?
that depends greatly on which motor into which chassis.
smp-16
Car: 95 240SX LE
Taylor_Durdan wrote:im shipping it this morning (yest was columbus day- boo) although i havent received my payment from him yet.
Just give James a call since im going to bill it through him . Thanks Taylor
Slipstream
Same deal, S13 blacktop into '95 S14 Chassis.
Initial_R90
Car: 2003 Zo6 Corvette RIP BLOWN up on the dyno
2003 Evo VIII
i'm also intrested in this
Taylor_Durdan
go ahead and shoot me an email
[email protected]
cartoonlips7
Car: 90,89,96 240sx
how much redtop s13 to 95 s14?
