S14 A/C blows hot
Cerevo
Car: 97 240 base
Hey all! In short, I have a redtop Sr in my kouki. Wiring Specialties wiring harness. The A/C compressor will kick on just fine, R134a canister shows good pressure when it's running, but the air never gets cold... I can swap an engine, take it apart and put it back together but I'm clueless to air conditioning..
kouki munster
Car: 97 base 240
Is the mix door moving? Stick your head under the dash and look/listen for anything moving while you move the temp adjuster.
Cerevo
Car: 97 240 base
Yeah it does. Its significantly hotter when I move the slider to hot as well
kouki munster
Car: 97 base 240
Have you checked the pressure on the high and low sides of the a/c? There could be a clog(or possible stuck expansion valve) some where in the system causing the issue.
