blackmagic »
https://forums.nicoclub.com/blackmagic-u56837.html
Tue Sep 29, 2009 2:30 pm
ok i figured out why im so confused. you can splice and connect the f3 plug pins 16(yellow/black, a/c switch) to 43(black/pink,tripple pressure switch signal) and the a/c should work other than the jump at idle. The thing is thats if you use the stock ka24de a/c compressor. Im looking for the wiring needed to get the s13 blacktop a/c compressor working on my s14. I have now tried what i think may work if somone could chime in and at least say its right or wrong. I just connected pin#11(green/yellow a/c relay on the sr20det ecu) to pin#43(black/pink,triple pressure switch signal on f3 plug) then I connected pin#44(blue/red,iacv-ficd signal on f3 plug) to pin#8(yellow/green, 12v to a/c compressor) let me know if this looks right. somone please
Modified by blackmagic at 5:50 PM 9/29/2009
