S13 SR20DET Alternator (KA24, Quest, etc.)?
BlazedGlory
My alternator has kicked the bucket. So right now I'm looking for a solution as quick as possible because my S13 is my daily driver.
I did a good bit of searching. I found out that you can use one from a KA24 if you swap the pulley and drill out the upper hole. But I've also read a bit about an alternator from a Nissan Quest. I found a thread about putting it on a KA and it said you can't swap to a KA pulley because it will rub, etc. but they were just running the 3 rib belt on the 4 rib pulley and it works fine...
I have a 5 rib belt on my sr I think, so I'm assuming it will bolt up to an SR with a bit of drilling if it will bolt up to a KA (and a KA will bolt up to an SR), but I guess the main problem/question is can you swap an SR pulley onto the Quest alternator? Or will it grind like the KA pulley?
If the quest one will work, are there specific years to get or something? Or should I just go with the KA and swap pullies?
Thanks!
