s13 sr20 intercooler kit.
89rb240
i was curious to know that the best intercooler i could get for cheap, i am on a tight budget.
Also. what is the most boost i can run through a stock s13 sr20? A guy at the local shop here said i could run 16psi no problem through the stock motor.
Help pleaseThank you
mRodiek
Car: Stock Hatch
your gonna wanna search my friend or you will get flamedFMIC kits are not cheap now a days but if you get a core off of ebay and buy the piping seperate you can save a ton of $$
you CANNOT run 16psi on the stock t25 turbo-many people push it to 14-15 but safely you shouldnt go past 13psi, but if you do that you are going to need:FMICboost controllerfuel pumpboost gauge
