fyrfyter06 wrote:Think I found the MAF problem... the solder on one of the wires broke, fixed that and figured out that I have a new problem. When I went to start the car, it wouldnt turn over. I smelled gas, so I figure its getting fuel, but maybe no spark?
It won't turn over, or it won't crank to idle?
If its not turning over - check battery - It HAS been sitting up, and could lose voltage. . .
If its not staying cranked, check through all the usual, plugs, coil packs, injectors, shoot if its been up for a while you might have a little gunk built up in the throttle body. . .or worse?
Good luck
