S14toRPS13 »
https://forums.nicoclub.com/s14torps13-u39149.html
Sat Aug 14, 2010 10:19 am
My gt2871R .64 hits full boost at around 4k rpm. Others people claims theirs reaches full boost a bit sooner, around 3700-3800 iirc. I think you meant the .86 in your above post, but the .86 will hit full boost later than the .64. Even then I still wouldn't recommend you go with 272 cams with these turbos. These turbos aren't considered laggy by the way. Looks like you need a lot of research to do. Just start searching around on this forum and others and you'll find out all about cam and turbo matching. Responsive turbos, laggy turbos, and then you can make an educated decision on what you want to do with your motor. You'll regret matching 272 cams with any of these smaller T25/28 turobs though.
